Hi all. Just rebuilt the top end of my typh malossi70..the last one, rhe standard 50's cylinders piston had siezed.. I bled the oil pump..undid the bleed screw.. and kicked it about 10 times, to be honest nothing happened, i though oil was supposed to start coming out of the oil pipe going to the carb..what i did notice is that the outlet pipe from the oil tank is completely empty, but the pipe to the carb is full... I started the bike and let it idle. im just wondering what exactly is happening and what i should do. Thanks in advance!
Lol i do mate thanks though sometimes stupid things like that happen but its pissing out of the oil tank!! someone help if possible as i dont recieve the correct tool to take of the flywheel so i can have a propa butchers at the oil pump...i think it works though coz it was filling with oil not to recently... cratch: Thankss
lol happens more often that youd thikn around here silly mopedders hah check its coming out of the oil tap thing on the bottom of the oil tank (just pull the pipe off and put back on if it is) then check if its getting into the pip its coming out teh other end of teh pipe(where it goes into the oil pump)
