can someone clarify weather the water/oil pump drive cogs (where the belt sits) should just pull off? the one on the crank is solid as is the bottom one where the oil pump does, pretty sure there is no other way that they are held in? thanks in advance guys
Piaggio? If i remember rightly the oil pump cog justs sits there and is only held in place by the pump itself. With this off it should come off freely
yeah 125 rolling nut mate, got it off in the end, where the water pump seal gave up on itself the water had corroded the cog quite badly but got it off at the cost of the pump belt, which was going to get changed anyway, thanks for the help tho mate
