I noticed today. Under my ped there was a small patch of oil, unerneath my ped. Where is this coming from, or is it a overflow can someone please help thanks..
What bike??? 2Stroke? mine did this becayse the oil tank/tub/box tubing wasnt fully on the tap cause of them loose butterfly clips jubilee on there and it wrorked :tup: but yeh need more info on your bike
ye so if it is a 4 stroke like u say then dont drive the bike until you have checked that there is oil in the bike!!! otherwise it will cost bucks!!! and how big was the oil leak/Patch??
check to see that your sump nut is tight or if the oil filter is tight!! if you cant be bothered just book it in for a service\!!! and ye if ur oil levels are fine then its just the overflow of oil that goes into the airbox! normal
Where can i find thes things to tighten, im new to scooters sorry. if you have pictures of the tings would help alot.
50cc the one in your pic i take it? try and see were the the oil's dripping from on the engine the follow it through im guyessing its straight off the oil pipe probably coming off the carb tbh
