nrgee problem pt2
Discussion in 'The Workshop' started by NRGEE, May 21, 2009.
  1. NRGEE
    NRGEE New Member
    Okay so about a month ago I made a post about my water pump on the nrg,
    I found out the pump is not the case, the bubbles that come out at the top and doesn't
    cool down them moped is due to air being in there..
    and the cap has a leak, I unscrewed the bolt on the cylinder and let the water come out,
    then i decided to take the whole thing off, the headgasket the think that the exhaust clips on,
    I found out that the dickhead before me put ltos of fucked seal on it, its all rusted, and blue seal is comming off with the rubber band, and on the silver metal thing the 2 rings are fucked.
    I need to know could that make the noise and stop my moped from cooling down and cut out after like 15 mins of running on normal speed?
    im sorry but im just fed up and really need someone that can help me,
    thanks.
  2. LEE
    LEE Member
    you should just take it to a shop will be sorted withing a couple of hours saves time and somthing that if you dnt no what it is could relive you of a big headache
  3. MiNoR cOnFuSiOn
    it sounds ,like a bodged up mess, and you sound incapable of fixing it...
    x2 take it to somone wiht a clue
