nrg wheels on 172 typhoon
Discussion in 'The Workshop' started by 172nrg, Mar 28, 2007.
  1. 172nrg
    172nrg Member
    i just hjl;
  2. StEvO
    StEvO Active Member
    if its the wrong size wheel ( which it is) then nope
  3. 172nrg
    172nrg Member
    drhfthfit
  4. StEvO
    StEvO Active Member
  5. SpAnNeR
    SpAnNeR New Member
    if your engine is new shape(clutch nut on the outside)
    you can either buy a runner 180 drum wheel (12 inch) or do a disc conversion.
  6. 172nrg
    172nrg Member
    it is wskhg
  7. MiNoR cOnFuSiOn
    cant convert one to nrg wheels unless its the old 108mm drum where as yours is 200mm... im working on doing a hub conversion so you can use a 50 hub with nrg disk wheel on a 125.... lots of work tho
  8. skatergod
    skatergod New Member
    i have a nrg rim here with the 5 bolts for the rear... drum one... i would use it on my typhoon but mine is the older style and needs 1 nut :msn1: so if your interested pm me...
  9. MiNoR cOnFuSiOn
    see where the 5 bolts go (the thing with the disk) its called the hub... this has the same size bolt/shaft (24mm)
  10. wobbly_trials
    his problem is there are no lugs to mount a rear caliper, herefore he needs an NRG drum wheel.
