NRG vacuum problem
Discussion in 'General Scooter Discussion' started by oliwest, May 22, 2012.
  1. oliwest
    oliwest Member
    aerox road legal pit
    Is there a way to get my nrg to work without the vacuum pipe being plugged in to the engine?
    I've fitted an mc3 engine which doesn't have the vacuum pipe near the intake manifold. What can i do?
    Also would the mc3 carb have any pipes id have to block as important using th nrg power carb atm but i think it's fucked
  2. ramo
    ramo GoldMember
    Get a manual tap or use the one on the carb?
  3. oliwest
    oliwest Member
    My carb doesn't have a vacuum bit on it :/
  4. ramo
    ramo GoldMember
    A stock carb should have a vac? I think you can put one on the crankcase if there isnt one but the crankcase vacuums arent good for fuel taps. Manual tap tbh.
  5. oliwest
    oliwest Member
    My old engine had on on the case by the manifold but this engine doesn't have one so i was wondering if the mc3 carb would have one so i can just do it easy. Will a manual tap
    be best bet then? :)
    Cheers
