nrg throttle
Discussion in 'The Workshop' started by 125TypHXR, Mar 27, 2010.
  1. 125TypHXR
    125TypHXR Member
    got a nrg throttle from ebay is there ment to be a spring in there so it snaps back or dose the throttle use the spring in the slide for that. :confused:cratch:
  2. MiNoR cOnFuSiOn
    the splitter works so well in these they only need the spring in the carb/pil pump to return to idle.. if your not running an oil pump just ditch the pump cable and run the throttle cable through the one wiht the hole and gold spacer (in the throttle splitter, 2 holes at the bottom, one holds a cable, the other doesent, you pull the sleve out and install the lil gold bit wich holds the cable for you) then its nice and easy to service the thing.. otherwise you have to remove the cable from the carb just to access the splitter.
  3. 125TypHXR
    125TypHXR Member
    yer oil pump got taken out in the week , thanks for info tho cos i was thinking the seller sent me a broken throttle. good job u replyed cos i wold haven wasted another tenner. :thumbsup:
