NRG Starting Problem
Discussion in 'The Workshop' started by O'z nrgPOWER, Mar 23, 2014.
  1. O'z nrgPOWER
    O'z nrgPOWER New Member
    Hey all, need help with my NRG basically...the other day I was doing my CBT it was running fine all day starting and stopping, after I had to go fill up with petrol and that's where it went down hill, and it didn't start but since I have checked for a spark and it has one.
    However when I had a proper look today I took off the airbox and petrol pissed out. It sounds totally dead when I kick it and using the button is the same still turns over but doesn't fire.
    If anyone has any clues on what it could be that would be great!
    Thanks.
  2. scubabiker
    Take your plug out, turn it over a whole load of times with no plug in it, put your plug back in and see if it starts.
  3. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Dirt in the fuel is my guess - you need to clean the carb out, especially the float bowl needle valve, as that's why petrol is leaking everywhere.
  4. Vespame
    Vespame New Member
    Vespa ET2
    Yeah I agree with merlin, sounds like your carb needs cleaned.
    If it was mine, I'd be cleaning the tank too. maybe (depending on the setup) putting a in line fuel filter going to the carburettor
  5. Merlin
    2007 TKR WRC 50
    This. Once you've cleaned the carb out, fit an inline fuel line filter, or you'll need to clean the carb again shortly.
  6. scubabiker
    Or do what I said....
  7. O'z nrgPOWER
    Cheers for all your help guys getting it sorted today! Will come back with the results.;)
