Nrg Problems
Discussion in 'The Workshop' started by smallz-16, Feb 28, 2008.
  1. smallz-16
    smallz-16 New Member
    My Friend Has a Nrg 70 Its Starts up and run but when u rev it, it dies he was told to clean the carb and chekc the manifold and the airfilter but that dont seem to be the problem can any one help ?
  2. alex_1966
    alex_1966 New Member
    try turning the air screw about a turn clockwise , then try it , it sounds like the fuel/air mixture is wrong , cant give u much more adivse cos im nt exactly an expert :p
  3. MiNoR cOnFuSiOn
    is it stock?
    if so clean the jet in the bottom of the carb, check the needle clip is still in place and check the float level is correct.
    if all this is fine on a stock bike how many miles?
  4. smallz-16
    thanks im goin to try all them things
  5. frazer
    frazer New Member
    hi this is the same on mine i changed the piston rings the other day and since then my biek has cut out at the lights a few times and i find the spark plug gets realy oily and is quite hard to start sometimes ?
  6. MiNoR cOnFuSiOn
    rich idle mix.. or too big a jet/heavy rollers
  7. frazer
    frazer New Member
    so which way should i turn the idle screw and i havenet changed the rollers or jets since i got it so its still all standered
  8. smallz-16
    still aint workin :msn1: it was running fine b4 up till the other week
  9. brettass*nrg*
    brettass*nrg* New Member
    my nrg was doin that it was wer it wernt the rite jettin and kept boggin out and shit try changing the jettin!! can u rev it but it jus wont pull off ??
  10. brettass*nrg*
    or 2 much air gettin threw the air filter if no fuk knows!!
  11. MiNoR cOnFuSiOn
    no
    its rollers...
    didnt realize they were stock weight. drop the weight by a gram or two depending on the pipe.. airbox makes it less sensitive to rolers but can easily be setup.
    jet needs upping obv.
