nrg problems
Discussion in 'The Workshop' started by oliwest, Mar 25, 2012.
  1. oliwest
    oliwest Member
    aerox road legal pit
    Hi. My nrg is dripping out a few drops of oil around the stand area and in the tranny cover. I cant tell if its a dodgy oil pump or the crank seals leaking. If it was the crank seals would that cause it to go slower? As it use to rev to 9000-9500 now it revs to 7000 an only hits 40mph.
    Cheers for anyhelp
  2. MARSH
    What colour is the oil? If it's clean 2 stroke then it could be crank seal, if it's black it could be from the exhuast flange on the barrel.
  3. oliwest
    oliwest Member
    Its normal clean 2 stroke
  4. MARSH
    Pop the sides off and check seals.
  5. oliwest
    oliwest Member
    Ill have a look later cheers mate! Would fucked seals cause the revs to drop an to run slower?
