nrg problem
Discussion in 'General Scooter Discussion' started by jmcleeds, Oct 10, 2008.
  1. jmcleeds
    jmcleeds Member
    ive got an nrg extreme lc with an 80 bore kit. i took the exhuast off other day to spray it and it started leakig water so i left it to dry. i put exhaust back on and tryed starting it for 10 mins and no luck. i too ehaust back off to find a lot of water and petrol in it, any suggestions? joe.
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    gaskets ok?
  3. jmcleeds
    jmcleeds Member
    yes head gasket is fine and so is exhaust gasket :confused:
  4. m1ck_t
    alot of shit
    base gasket?
    waterpump?
  5. MiNoR cOnFuSiOn
    80 kit?
    its gotta be the head or base gasget... or the case is cracked
  6. jmcleeds
    jmcleeds Member
    it was leaking from the exhaust hole, it only happened once i took exhaust off
  7. MiNoR cOnFuSiOn
    the exhaust hole? LOL
    ye, its your BASE GASGET OR YOUR HEAD GASGET
    the fact you took your pipe off is irelevant.. unless you used an axe/hammer to remove the pipe
  8. jmcleeds
    jmcleeds Member
    ok, can they just go ay time then? and i still dont understand why liquid would gather in the actual exhaust pipe :confused:
  9. Aerox-lad
    Aerox-lad New Member
    because its leaking out the barrel into the exhaust. THINK liquid goes with gravity which pushes it into the exhaust chamber.
  10. jmcleeds
    jmcleeds Member
    so does the base gasket stop the water from entering the barell? and it has broke and gone into the barell
  11. m1ck_t
    alot of shit
    mate, just have a look for yourself, if its fucked, get a new one, of it aint then keep looking
  12. jmcleeds
    jmcleeds Member
    i have replaced the gaskets, and cleaned out the cylinder and head. still it wont start, any ideas? the carb isnt blocked and no loss of compression and there is a spark :confused:
  13. Jamie
    vaccum pipe on?
  14. jmcleeds
    jmcleeds Member
    ye it is
  15. m1ck_t
    alot of shit
    fuel getting through? is the plug wet?
  16. jmcleeds
    jmcleeds Member
    the plug get wet, as silly as it sounds i have took cylinder head off and kicked it over and you can see the petrol in it. i have taken cylinder off and all is ok, no gaskets are broken :confused: its baffeling me. normally if i ever have a probem i can fix it but after hours of looing i cant find anything wrong :confused: please try help lol
  17. MiNoR cOnFuSiOn
    got a decent spark, used a new plug? checked everything silly? do compression test.. might be dead rings
  18. jmcleeds
    jmcleeds Member
    good spark yes, how do you do a compression test? the compresion seems to be good. and no air is leaking out :confused: i spet 6 hours yesterday lloking and cant ssee a thing .
  19. jmcleeds
    jmcleeds Member
    oh and the rings look new... the guy said he had them replaced a month or two ago
  20. jmcleeds
    jmcleeds Member
    just tipped the bike to shake out any water that may have been in the crank casing... still doesnt start : :wtf:
