nrg power headlight mod
Discussion in 'General Scooter Discussion' started by phil.s, Apr 28, 2012.
  1. phil.s
    phil.s Active Member
    Ive seen a few nrg powers on the net that have modded there headlights so both are on at the same time. as they are at the min one light is the low beam then when you hit full beam the other headlight comes on and the other one stays dimmer so only one of the headlights is lit at once if you get what i mean.
    What i want to know is how do i have it so both lights are on for low beam and then when i hit full beam both are on bright ? cheers
  2. MARSH
    As far as i know you can't, one is dip and the other is main beam, that's how it works. You can't have both.
  3. phil.s
    ive seen some with it done tho ?
  4. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    with some extra wires im sure you could solder it up so both come on. i have done it on aftermarket headlights. and my runner has a little extra bit to the lights switch that allows you to run both, im unsure if this is meant to be the case but it works. it did however seem o run my battery down quickly
