nrg mc3 forks
Discussion in 'General Scooter Discussion' started by NRG2002, Oct 17, 2013.
  1. NRG2002
    NRG2002 Member
    Does anyone know if the old shape gilera runner 50cc forks will fit the nrg mc3 and if they will be a straight fit cheers
  2. MARSH
    No, the steering stem is a different length.
    NRG2002 likes this.
  3. PDBV
    PDBV Member
    I have just put typhoon forks on mine only things i come across that need changing is the spindle speedo drive and brake disc !
    Sent from my GT-N7100 using Tapatalk
    NRG2002 likes this.
  4. NRG2002
    NRG2002 Member
    When you say the spindle speedo and brake disc do you mean to change them to a nrg on or use the typhoon one cheers
  5. NRG2002
    NRG2002 Member
    Also is there any other forks that fit the nrg off other bikes thanks
  6. PDBV
    PDBV Member
    The typhoon uses a 190 mm disc and if yours is the same as mine it will have a 220mm disc so that needs changing to fit, the spindle on the typhoon is a different and the mc3 uses a pinch bolt spindle, and also the speedo drive locates slightly different on the typhoon but you can either mod the one you have to fit the typhoon forks or you can get the typhoon one, i have no idea weather any other forks fit
    NRG2002 likes this.
  7. NRG2002
    NRG2002 Member
    Well looks like my forks are not cost effective to repair they need the damper,two chrome stems, bushes and spacers,and seals,will need to find a second hand set or a second hand nrg mc3 that is being scrapped and have a few bit off it as well.
  8. StEvO
    StEvO Active Member
    NRG2002 likes this.
  9. NRG2002
    NRG2002 Member
    What sort of price are you looking for them judging by the forks they will be the best thing on the bike lol and they are for the NRG MC3 cheers
  10. PDBV
    PDBV Member
    I bought a set of uprated ones off the bay for £130 in mint condition just to give you a very rough idea on price
  11. NRG2002
    NRG2002 Member
    Problem solved thanks to StEvO details all sent
