NRG MC3 electrics
Discussion in 'The Workshop' started by mxriderace97, Jan 29, 2014.
  1. mxriderace97
    mxriderace97 New Member
    RM 125 , NRG 70 yz85
    My headlights tail light and brake lights work
    But everything else doesnt
    Indicators
    Starter button
    Horn
    Petrol gauge
    Battery gauge
    I just put in brand new regulator with flasher built in still doesnt work brand new battery in aswell still no results
    Any ideas
  2. Datahar
    Datahar New Member
    Piaggio NRG
    Almost identical problem to me!
    I went to post a thread and saw you've written it for me
    My headlights and brake lights work once engine is running, the only light on dash is the light indicator, although my fuel guage does work, I thought it wasn't, then I ran out of fuel and figured it out! :p
    when I apply the rear brake the fuel indicator starts to drop, so I am thinking there is a bad earth somewhere?
    I also bought a new regulator but that didn't help, just bought a new starter relay as that came apart on me, so I am hoping the earthing problem could be in there, will let you know
    I ran a voltmeter on an indicator and there was some juice going to it, then the loss when applying the brake, would be interested if you are getting the same symptom
    p.s sorry this isn't a solution...
  3. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Been there. seen this.
    Donna's Peugeot V-Click had this problem recently and it turned out to be that a multi-pin plug had come undone inside the front fairing. Her bike had been dropped and the impact pulled the plug out. On her bike, it was a blue multi-pin connector.
    Have you checked the inline fuse from the battery? If that's blown, you'll lose all of the indicators, horn, brake light, electric starter and fuel gauge.
    The head and tail lights work off the generator and don't use the battery, so don't take those into account.
    Check the fuse, check all block connectors between the battery and handlebars then check all earth (usually green) wires, to make sure they are connected to clean metal and are tightly attached.
  4. mxriderace97
    Took all the panels off thoroughly cleaned all the plugs
    Found quite a few loose connections all over the bike
    I think these bikes have a circuit like christmas lights one loose connection everything goes .
    Once i did all this all the lights , gauges work but when i turn the key petrol light and oil light dont show up (red and orange light) anymore like they use to any suggestions?
  5. Merlin
    2007 TKR WRC 50
    Well, they are designed to warn you of low oil and petrol and if both are full, then the lights will be off. I don't think it's broken so try it and see how you get on.
  6. Stevep
    That was an easy fix then merlin!
    Hope she made you a cuppa?
  7. Merlin
    2007 TKR WRC 50
    She did indeed, Steve. :)
  8. Stevep
    I just had this on an nrg as well.
    No rear o/s indicator, no starter motor, half the dash didn't work, turned out somebody had cut 6 of the earth wires in the loom and twisted them together and then used black insulation tape to cover them.
    Once i found the lump in the loom, (behind the right seat panel) and cut the corrosion out and fitted them to a multiplug instead of soldering them, everything worked again.
  9. Merlin
    2007 TKR WRC 50
    This is the absolute truth!!
    turbovetto likes this.
  10. mxriderace97
    im not sure whats happened really it shows if its low on petrol oil etc everything working
    but every moped when you turn the key the lights turn on red and orange then turn off
    then you start it mine dont do that anymore . is it really only when its low on pet and oil i thought it shows no matter with or without these peds have got me going round in circles
  11. Merlin
    2007 TKR WRC 50
    I'm going off my experience with my TKR 2. The warning light for the oil tank doesn't come on until the level is low in the tank on my bike. The ignition light comes on and goes off when I turn the key.
    Check the connections to the CDI unit and ignition switch, as it can only be one of these two that is causing the problem. Can anyone else with more experience of Piaggio machines help out with more advice please?
  12. Starboyjaffa
    Starboyjaffa New Member
    My nrg mc3 brake lights and front light don’t work but all the rest of lights does I have checked the fuse new battery and checked the bulbs
