nrg just wont run right
Discussion in 'The Workshop' started by oliwest, May 24, 2012.
  1. oliwest
    oliwest Member
    aerox road legal pit
    It was the same on my old engine. They just never run right. Could it be my carb is dodgy? I've tried jetting, mixture screws etc
    should my float just dangle when i remove the float bowl? Sometimes fuel drips out from where its held on
    cheers
  2. gilly_runner
    gilly_runner Member
    Gilera runner
    What does it run like ? yes the float should dangle, you say fuel leaks if it's from where the bowl and the carb join make sure the rubber gasket is there and clean it. If its leaking from the bottom pipe (overflow) your float hight is too high and this will cause the bike to not run good at all anywhere under half throttle and stil will not run right above half throttle.
