Finally managed to start my NRG today so I took it for a spin, it struggled to pull off and was bogging until the clutch kicked in then the usual hairdryer noise start and it took off. When reaching around 50mph it starts cutting out and bogging badly. I have to release the throttle and put it back on, then it 'might' pick up. While it was out it totally cut out and wouldn't start so I had to push it home (LONG). I've tried tweeking the carb but no difference at all...I managed to stop to excesive smoke coming out the exhaust thats's about it. Someone please help
it sounds like wat my bike did try cleaning out the carb and bowl and try cleaning the petrol tank mite be a bit of shit in there
sounds abit like crank seals but work u way up check for good spark fuel gettin throw clean carb out ect 7
Just an update... due to the horrible weather I haven't bothered to start on the bike but if it gets nicer anytime soon I'll be straight on it
yeah i know my bike needs a new oil pump and i got a project bike to do but the weather is so shit were u from any way
Managed to get an hour without rain and cleaned out my carb and petrol tank.... but how do I get the fuel to go down the line into the oil pump... I think I need a new one tbh! I'm from essex mate, you?
update, it stopped starting and turns out it was a spark plug that was a week old. But its back to bogging again...carbs all fine, brand new plug plug, it does start but just bogs and cuts out. Or when I touch the revs it dies, what could it be?
try adjusting the mixture screw but make sure you know where you started from...go half a turn at a time
try to empty the tank thats wat i did n clean it out then put new petrol in it or could be the oil pump
I've cleaned out the tank, the carb and everything. I'm gonna clean out and upjet the carb after work
mate i had this problem i went out on my bike in the rain 10 mins later it started to bog anova 10 mist it cut out got it goin but would not move badly bogging then it cut out and wouldent start i fort it was carb water in it cleaned out dident do a thing so got new plug br8es and it started but as soon as i touched the revs it cut out so i got a br9es plug and it was fine so wot plug u got in nw or it might be bad cdi not giving a good spark
I just bought a br9es plug it starts but cuts out after a couple seconds. Its got be something with the mixture.. Can someone explain the mixture and idle screw to me. I know what they are but screw with way for what?
