nrg help
Discussion in 'The Workshop' started by luke gooding, Jul 6, 2012.
  1. luke gooding
    luke gooding New Member
    ridin my nrg power today and it cut out an wont start press elecstsrt an it does nothing at all. but all elecs wfkin any1 help
  2. Edgar
    Edgar Active Member
    i had this problem when my belt snaped and it jammed the starter so it wouldnt start, just do usual checks , check if there is spark, take side case off etc
  3. luke gooding
    i changed belt yesterday?
  4. luke gooding
    also had a new spark plug
  5. roxy boy
    roxy boy Well-Known Member
    roxi
    could be the belt is too tight ....should stretch out after a while just kick start it for a week and see if its better
  6. luke gooding
    it wont start start at all thw?
  7. roxy boy
    roxi
    have you checked all the things ....if you can remember back from school there is a fire triangle its same with motor bikes
    Fuel​
    heat oxygen​
    so check if there is fuel on the spark plug ,,,if there is check heat(spark) and check air filter not clogged up​
    if there is no fuel clean carb blow jets through...if there is no spark check earths, input /output of coil ...then try and swap the cdi over eg borrow one of your mates cdi​
    check for broken wires and dirty connections ​
