nrg hard to push
Discussion in 'The Workshop' started by wheelieboy, May 6, 2008.
  1. wheelieboy
    wheelieboy New Member
    right my piaggio nrg is:
    really hard to push but somthimes its easy,,
    what can it be??
    may it be the bearings??
    cheers
  2. alex_1966
    alex_1966 New Member
    if it was the bearing youd definetley hear a noise while riding it , most likeley its one of your brakes rubbing
  3. wheelieboy
    i have starting hearing a slight wineing noise
    soo i think it may be the bearings am i right?
  4. Jamie
    If its disk brake, then bleed the fluid and top op. sometimes air bubbles build up and occasinally they stick abit, if its drum brak then check one of the springs hasnt snapped etc...general maintainance.
    If its non of the above its most likely clutch related ;)
  5. wheelieboy
    ok thanks jamie!
    will take the back wheel off tomorrow and check
    cheers
  6. capri dave
    capri dave Active Member
    stick the scooter on the centre stand, or stick something under the scooter to raise the back wheel off the ground....
    then turn the back wheel by hand, if it feels stiff....you can unbolt the back caliper and check again to eliminate binding brakes from the equation ;)
