Well the NRG and Typhoon frames are near identical apart from a few mounting points for panels, rad etc. so I'd expect if it wasn't actually the same fuel tank that it would fit fine.
gonna be useing a nrg front pan so not gonna be useing the front tank , looks like the nrg one is bigger but not by much.
there bigger at the botom.... hold alot more fuel than the typh. im not actually 100% on wether they clear the typh pans but theres one deffinative way to find out. i doubt you will run into any problems tho fella "should" fit fine, altho it will hang out the bottom
