NRG Forks on a Typhoon 125
Discussion in 'The Workshop' started by fabolous Phil, Jun 13, 2007.
  1. fabolous Phil
    fabolous Phil New Member
    not sure if its been asked but i checked and didnt find it so quick questions,
    1. Do nrg forks fit straight onto a 125 typhoon with no modding necersery (125 frame) and if they do can i run both locking nuts .?
    2. do i need a new caliper or is my typhoon one fine .?
    thanks
    phil
  2. MiNoR cOnFuSiOn
    bolt on fine and caliper fits.. wont be able to fit the typh wheel as it will have a smaller disk (in most cases) some of the nrg's had a small disk on the front and typhoon forks tho so check what they are. if its a 3 bolt disk it will take your typhoon wheel, if its a 5 bolt disk it will need an nrg/runner wheel. everything else fits tho (speedo cables off other bikes for whatever moddle) steering lock works fine too. its a straight swap other than the wheel
  3. fabolous Phil
    thanks, what about the rear one, its new shape engine if that makes a difference, its got 180 gilera drum one at the moment but dont wana buy a nrg wheel if it dont fit, would it have to be a/c drum nrg wheel .?
    thanks
    phil
  4. MiNoR cOnFuSiOn
    the 125/180 engine uses a 200mm drum (unless its an old shape typhoon engine) ALL the 50's have a 108mm drum. so the nrg wheel wont fit any 125 engine unless its an old shape typhoon... can see if its a small drum or big pritty easy as the small shape 125 doesent have a dipstick on the back ;)
