both the same link mate, and u cant link direct just name the parts and ill probably know what ones u mean.
sorry links dont work It is a reed block hebo with carbon fibre reeds and the intake manifold de ristreicted manifold which fits 21mm delorto carbs
hebo block isnt as widely used, the best one on there is gonna be the vforce3 reedblock, need to buy a sheet of CF reed and cut your own, but the result is worth it. i wouldnt bother with the manifold tbh, if you do, go for the polini item, its much much better.
will it make alot of differenceif i change the reed block from standard? and i think i need to change the intake as standard is only 17.5mm
when it mentions bearings it comes with it means the bearing in the crank on ether end of the conrod not mains
hi again i am just wondering are the malossi mhr carbon reed blocks any good because they arnt much dearer than the hebo ones and they will match my cylinder kit thanks ash
i have a mhr rep one on my bike but only got it because my other was fooked. dont know what the mhr is like .
ok thanks i think am going to go with the malossi ones as they arnt that dearer and match my cylinder kit. So far i am getting: Malossi mhr rep 70 kit stage 6 21mm delorto carb yasuni city 16 bgm crank bgm pro mains bearings and seals de restricted 21mm intake manifold malossi carbon fibre reed block could anyone please advise on any needed aditions or changes? thanks ash unk:
you might want a gear up. depends what you want. and i would order a box jets and a couple of sets of rollers so you can get it right
i am looking for mostly acceleration so light weight rollers and i will buy the box jets to trail and error them. Does the above sound like a good kit to you?
As i said somewhere else... The Polini evo block is the best. That's coming from someone with a MHR reedblock fitted to their bike. Edit: Oh and if i was you i'd buy a torque drive too. Did wonders on my MHR Rep setup.
i just dont really want to mess about cutting my own reeds and fort for the slight difference i may aswell buy the mhr rep reed block. what is a torque drive?
Cutting your own reeds is for the stage6 vforce not for the polini evo. The Polini evo is pretty much the same as the MHR but slightly better.
ok thanks what did u meen by torque drive? do you know if there is any guides on fitting these parts?
