Hiya i own a nrg dt 50 i am looking into buying the following performance parts: Malossi mhr rep 70cc kit Malossi mhr 19mm carb leo vince zx exhaust Will the exhaust work well with these parts? Is this carb the correct size for max perforance? or should i get a 21mm carb? i am looking to get the most performance out of my scooter rather than reliability. could you please advise any other parts or changes to my current list? Many thanks Ash
go 21mm and forget the zx, laser or yasuni c/city 16 are your best bet, slightly more money but better pipes
Any reccomendations on a carb make? what would you personaly reccomend out of the yasuni and the laser? Thanks for the quick reply :tup:
dellorto for the carb as they are all basically the same mate and i would say that the c16 is the best out of the two for that setup but also the more expencive i believe
Will the c16 come with the correct clutch springs and rollers for my setup? or will i have to experiment with different weights?
i dunno to be honest mate i have never bought one my self, but usually you would have to experiment anyway even if they are included as they are usually wrong
ideally you want: C16 (or city 16) mhr rep bore 21mm del carb variator (multivar or polini) kevlar belt a set of harder clutch springs or a complete clutch (polini would be my preference) possibly a gear-up depending on your type of riding carbon reeds or an uprated reedblock you will need to have a play with jets to get the correct one as with rollers.
The washer in the variator has been removed and the previous owner has fitted a leo vince TT exhaust. are there any other restrictions beside these? First i will be buying the big bore, exhaust and carb, then i will work my way down your list could you reccomend a few jet sizes to try? Which item should i buy next out of the ones youve listed?
Check the inlet manifold, if it has a small opening then that is restricted. Also in the carb mouth where the airbox joins, theres a little gold plate
It will be about £10 tops www.scooter-attack www.scootercenter.com Are cheap and should both sell them Dont forget jets
I'm guessing your carb is a dellorto 17.5mm so standard jet would be 56 Buy a stage6 jet box which comes with 10 jets
