NRG don't run smooth
Discussion in 'The Workshop' started by brainjuicer, Nov 2, 2010.
  1. brainjuicer
    brainjuicer New Member
    Guys i have nrg mc3 lc i open it for water pump changing, i saw that my reeds was damage too and i buy new malossi. I Close the engine, the first 50km's the engine run good like before the opening but after that in high rpm's (after 8-9) or on full trottle it chokes.. i must give up half trottle to run to top speed or run normal.. i start to search for the problem, it's not from the gas or oil lines, its not the carburator mixture or transmission problem, can it be from the reeds? ideas?
  2. e_deher
    e_deher New Member
    could be...hold them up to a light or the sky and if you can see a crack between the reeds and the block try to replace them...sounds like a carb problem to me though
