Hey, when i start my NRG up, it bogs when i first accelarate. I have to keep the revs up otherwise it would bog and set off really slow when pulling out into a road. This is becoming a problem, help please!
have you alltered the jetting to suit the new pipe and changed the roller weights to suit the pipe as well
like oli said i have the same pipe on my nrg and a 62 is just on the rich side so a 60 is spot on but thats with the stock air box fitted.
mine has the stock air box, it ran fine up until about 2months ago when it started to bog? so it can;t be the jet.
hmmm... weird... have you checked belt rollers ect??? also check the clutch springs... that could be the possible problem...
