nrg 172 tphoon engine n loom battery terminals
Discussion in 'The Workshop' started by ben172, Dec 3, 2007.
  1. ben172
    ben172 New Member
    hi i was wondering if anyone can help me im doin a nrg 172 project and ive got most of the electrics converted over to fit the nrg im haveing trouble finding the battery terminals ive manage to find how the red one goes on the relay to the fuse and to the plus termnal but i cant seem to fing the negative one so is there any person that can tell me how i can make one up is it a case of just earthing it to the frame then running it to the neg terminal if that make sense and ill be putting it in the project bit soon thanks
  2. Speedy 172
    Speedy 172 Active Member
    got the same problem with my sr loom
  3. MiNoR cOnFuSiOn
    yup, black just goes to the earth by the relay. got the rest right
  4. Speedy 172
    but theres like 5 black wires minor
  5. MiNoR cOnFuSiOn
    the 5 on the loom all need earthing to a point there closest to. any black is just an earth, there is only one to the frame from the batt and the engine is earthed via the starter cable.
  6. Speedy 172
    well where do they all earth to its so confusing can i not just earth um all to the frame ?
  7. MiNoR cOnFuSiOn
    just said that... :D all to the frame. the starter wire too and just run one from the frame to the batt... DONE ;)
  8. Speedy 172
    is the starter one the one that comes from the engine :D ??
  9. ben172
    ben172 New Member
    thanks minor that sorts that out be doin that tommorow and then sort sum off the switches out on the typhoon loom thay have a hi and low beam switch and a switch to turn the light on and off like the runners do or dont thay as ive got 2 switches on the typhoon loom and when i run a live to them the dash lights cum on and same with the other plug hope that makes sense lol
  10. MiNoR cOnFuSiOn
    theres 2 switches.. one 3 position for *off, side, main* and the other 2 position switch for *dipped/high*
  11. ben172
    ben172 New Member
    thanks mate hopefully thay all work when i get a battery on there thanks minor im pm u if thats ok about some porting work i herd you do thanks again
