nrg 125
Discussion in 'The Workshop' started by scottnrg, Oct 11, 2008.
  1. scottnrg
    scottnrg New Member
    can anyone help il drive my ped for abit an then it will like bog out or just cut out an if i leave it for a couple of seconds it will start up an drive alrite for abit an then do the same again anyone got any ideas cheers
  2. scottnrg
    scottnrg New Member
    can anyone help please
  3. Biggie
    Biggie New Member
    Why dont you say whats done to the bike or even if its standard.
    what carb has it got? jets?
    reeds? manifold?
    spark plug? plug cap and lead?
  4. MiNoR cOnFuSiOn
    sounds like float level.... has it got a 25? if so check for worn parts on the corner.. might be a shitty float sticking, might be the choke messing.. as said we need a speck and whats been done befor we can really help ;)
  5. Vesta
    Vesta New Member
    My mates did exactly this and the garage said they replacedhis crank seals to fix it
  6. scottnrg
    scottnrg New Member
    the spec is standard 125 runner engine with air box an its has a 90 jet an the standard 20.5mm carb cheers
  7. scottnrg
    scottnrg New Member
    please can anyone help really need to get this sorted cheers
  8. scottnrg
    scottnrg New Member
    bump really need help
  9. LEE
    LEE Member
    my old 180 just to do the same thing it turnt out to be the pipe kept coming loose the one coming out of the casing under the reed block
  10. scottnrg
    scottnrg New Member
    ok mate il check that
  11. scottnrg
    scottnrg New Member
    i have checked the tube that lee said about i have also changed the choke an checked the float an it looked ok it also now has a malossi airfilter with a 95 jet but is still doing the same thing can some one please help because i really want to get this done an go for a drive cheers
  12. scottnrg
    scottnrg New Member
    minor i could really do with your help please
  13. MiNoR cOnFuSiOn
    check fuel delivery... for the second time
  14. scottnrg
    scottnrg New Member
    i have checked that minor an its ok
  15. MiNoR cOnFuSiOn
    ok.. so its running, then when hot dies... check the choke. an i dont mean go look to see if theres one there.
    change the plug, do a compression test and then finally if nothing cures it change the seals.
    what is it, ac wc?
  16. scottnrg
    scottnrg New Member
    its a l/c gilera runner engine cheers il try that
  17. MiNoR cOnFuSiOn
    erm, what rads in there?
  18. scottnrg
    scottnrg New Member
    its got a gilera runner 125 radiator really want to get this sorted
  19. scottnrg
    scottnrg New Member
    also minor how can i check to see if the choke is working cheers
  20. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    these used to happen 2 me on my typhoon chage plug ,wat carb u got , wat petrol tank u got a 50 nrg 1 .check coil and ht cap they mite be loose ,but if im right u have a petrol prolem a wen it cuts out there no petrol in your carb because wen it happend 2 my typhoon i had a clear float bolw and there was no petrol in my carb then after 5 second it would come thoe, check your petrol tap ant fucked i
