NRG 125 just bogged out
Discussion in 'The Workshop' started by GARLAND, Mar 29, 2008.
  1. GARLAND
    GARLAND New Member
    I went thru a little splash of water by accident and my ped bogged out i've taken filter of and im drying it now what else should I do?
    Bike wont start.
  2. capri dave
    capri dave Active Member
    take the plug out as its probably wet with excess fuel, from when the filter got wet and made the engine run rich ;)
  3. Jamie
    leave overnight to give the cdi and other exposed loom bits to dry. take plug out and turn the engine over for a few seconds to get any eccess shit out. put a new plug in dry the filter and it should be ok
  4. MiNoR cOnFuSiOn
    spray everywhere with wd-40 and leave it for 10 mins... bit in the carb wont hurt (only a small squirt at full throttle)
  5. GARLAND
    GARLAND New Member
    i used silicone spray its all i had is the same lubricant
    ill goto bed now and leave it till the morning.
  6. MiNoR cOnFuSiOn
    wd-40 does not and has never contained silicone hence can also be used as easy start.. its a cleaner more than a lubricant, water dispersant where as silicone spray is a lubricant. totally diff ;)
  7. GARLAND
    GARLAND New Member
    Ok
    I checked spark it sparks cos i got a shock.
    Theres compression coming out the exhauhst.
    But it's not starting on elec start =[
  8. capri dave
    you have to check for a strong visible spark...getting a shock only means electric is going to the plug!!!
    its what happens once it reaches the plug were interested in ;)
  9. GARLAND
    GARLAND New Member
    My carb keeps flooding randomly, yesterday ti died when I was driving home just lost all power slowly now wont start?
    82.5 jet standard 125 carb and a doppler air filter/malossi big red
