I bought this scoot as a non runner and not knowing anything about modern scooters, can anyone give me a clue. Has no spark and starter motor won't work on the key. Starter works if I power it direct. I think the immobiliser is missing? there is no ring thing around the ignition switch.
I have checked the starter relay which is working ok. Also the indicators and brake light work with ignition switched on.
No spark is any number of problems; from dead cdi to wiring to no power feed to flywheel to pick-up to stator........ First thing is to get it cranking over on the button. Open up the switch gear, check for power to the rear of the starter button, then check for power out the other wire from the button when you press it. Then trace the wire to the starter relay input, then out the output side of the relay. And check the engine earths as well.
I found out that the front brake needs to be applied then it will crank over and has a spark. Now I have to check the fuel supply as it won't start.
