No electrics No spark
Discussion in 'The Workshop' started by torpedo01, Apr 4, 2015.
  1. torpedo01
    torpedo01 Active Member
    Pedal Bike M8
    Having issue after issue with the SYM jet 50
    No electrics now and no spark
    ignition on no indicators no horn fuel gauge doesn't move even though theres a full tank nothing happens checked for spark and theres no spark now
    was running and riding fine last week
    battery is fine too
    any ideas?
  2. technodimwit
    technodimwit Active Member
    Honda X8R
    check for a loose wire behind your ignition key switch, must a loose connection somewhere. also try the battery connections are nice and tight
    torpedo01 likes this.
  3. torpedo01
    Pedal Bike M8
    battery connections are tight
    ill check ignition when I can get front panel off
  4. torpedo01
    Pedal Bike M8
    fuse is fine. don't think its the ignition ill get all the panels off to find earth wire tommorrow
  5. scootzmadness
    youll find your earth wire is under the front panel not far from the ignition, next to the horn, two wires green and red. your scooter just doesn't like you because your a fudgepacker. That's why you have so many issues with it. get your dad to move the earth to the frame with some ring connectors from speedys instead of them being where they are.
  6. torpedo01
    Pedal Bike M8
    Fixed it loose earth cable under front panel started straight up when I put it back on properly
