No electric start :((((((((
Discussion in 'The Workshop' started by Bullet125sp, Sep 4, 2009.
  1. Bullet125sp
    Bullet125sp New Member
    125 SP
    ive got no electric start, the battery turns the bike over but it just doesnt start but it starts on first kick :confused:. ive tried another battery but still with no luck any suggestions?
  2. alperin
    alperin Active Member
    aerox 180cc
    kl, check that the starter bendix is there underthe variator and battery has to be charged properly as it needs alot of power to get the bike started
  3. Bullet125sp
    125 SP
    do u mean the starter pinion? if u do then yer its defo there as the bike turns over jsut wont start
  4. Bullet125sp
    125 SP
    here quick video
  5. rideorcollide
    rideorcollide Active Member
    TYPH 172
    is youre earth wire tightings?
    dont sound like its the earth but thats the only thing thats stopped mine starting.
    it sounds like its immobilised or summin o_O
  6. Bullet125sp
    125 SP
    i dono but its pissin me off. ALL other electrics work so i dono
  7. rideorcollide
    TYPH 172
    could be something to do with youre bike setup.. coz it sounds like its turning enough to start the bike... but you know how a kickstart always starts it better than leccy start.. hav a play with youre idle settings blo0d
  8. Bullet125sp
    125 SP
    i might do that homebody when i can be bothered...its prob cos the bikes toooooo powerful for leccy start
  9. rideorcollide
    TYPH 172
    nah it cant be otherwise mine would never start homeslice
  10. MiNoR cOnFuSiOn
    if a bike wont start off the electric start yet starts with a hard kick its ether a shnit battery (jump start from a car/booster pack) or your down on copmpresison..., thi si the first sighn that your piston rings are on there way out as theres not enough resistance in the engine to produce the pressure for the second cycle of the engine that starts the bike, where as a hard kick spins it just fine,
    but confusing.. but check wiht a booster pack or jump off another battery.. if its no good your ether down really bad on compression, have a lazy starter motor or your too high on compresison (doubtfull)
  11. Bullet125sp
    125 SP
    yer ive tried to battery both just dont have any luck. sometimes i notice that when the bike starts off the kick it wil cut out after a few seconds but when i rev it a little it stays on idle fine for as long as you want?
  12. wobbly_trials
    if its not already been said its the ballast resistor that's gone pop.
  13. MiNoR cOnFuSiOn
    only the old old runner's have these installed....
    bikes DONT start better off the kick, bikes wiht worn rings do (has anyone in this thread ever owned a new 172?)
  14. Bullet125sp
    125 SP
    i had a brand new kit on my old 172 lol...ive ordered new rings and got new bushes so ill do em all when the rings come. thanks minor il get back to ya see my results not doubt your right :)
  15. rideorcollide
    TYPH 172
    no :pale:
  16. johnwf
    johnwf Member
    Dragster 180, VFR800
    I do not know what is causing the hard start, but I purchased a 180 dragster several months ago which had the same problem. I found that if I cracked the throttle open ever so slightly then the engine would fire on the starter. This did not cure whatever was causing the problem but it did start the engine on the starter motor (so maybe something wrong with the idle circuit in the carby).
  17. Rick-UK
    Rick-UK New Member
    Runner 200
    Don't know if it counts but my old speedy was a reallll pain using the kick, but electric start was nearly instant.
  18. MiNoR cOnFuSiOn
    rings rings rings... shit compression on low mix (idle) meaning the rpm of the starter just isnt enough to draw and compress an ignitable mixture.. opening the throttle gives it more mix of air and fuel=more compression=fires up.. kicking raises the rpm of the engine thus the same compression but more in the same time = fires up.
    worn rings mean poor compression, the first sighn of ring wear is an inability to start on the starter when its fine on the kick.
    every story in this thread is ring related
  19. 3man 172 runner
    3man 172 runner New Member
    runner 172
    sorry to change the subject totally but minor i have been reading alot of your posts and i was just wondering how how you know all dis stuff bout bikes and porting and stuff. and how much you charge for porting if you do ?
  20. MiNoR cOnFuSiOn
    i know what i know from making mistakes and doing it wrong for years.... aint long befor you make every mistake you can and know how to avoid them all. its the only real way anybody learns.
    pm for porting enquirey's
