Newbie oil pump question
Discussion in 'The Workshop' started by TomCAprilia, Dec 6, 2016.
  1. TomCAprilia
    TomCAprilia Member
    Aprilia SR 125
    Just need advice on the correct name of the adjustable screw that adjusts the oil pump cable.
    The screw screws into the engine casing containing the oil pump end of the throttle cable. (2t obviously)
    If someone could tell me what these screws are called because I've been looking for a replacement all over the net for my SR 125 and havnt had any luck so far. Thanks.
    Also wondering if there are any decent mechanics who could do some work on my SR around Liverpool as the number of good mechanics round my area are limited and therefore there always extremely busy and very expensive.
    I need to replace my throttle cable but there are some seized bolts on the engine casing and shroud. I don't trust myself. I'll only make it a bigger job!
    Rather give someone with experiance and spare time the ££ to just crack on with it.
  2. MARSH
    Err, Oil pump cable adjuster! I'm sure I've got one lying around, pm me your address and I'll post it to you!
  3. TomCAprilia
    TomCAprilia Member
    Aprilia SR 125
    Thanks a lot man. Havnt had a chance to get on much ill PM you my address in tommorow. If you could send me an adjuster screw that would be excellent!
