New Tuning Parts Advice
Discussion in 'General Tuning' started by 2strokeracer, Feb 6, 2008.
  1. 2strokeracer
    2strokeracer New Member
    Hey all,
    My last tuning parts i am adding to my Aerox Arrived today, which are:
    Dellorto 17.5mm Carb
    Malossi Clutch springs for my MHR Delta clutch (White, Yellow, Green)
    Malossi Red Sponge Filter
    Destricted Manifold for Carb
    Could you fellaz give me some advice on what jet size i will need to use. It came with a 90, but obviously will have to adjust due to my setup.
    Also i was thinking about using the yellow springs with 4.5g rollers.
    I have been told some scooters need a new throttle cable to suit... Please dont tell i need one!!!
    Thanks in advance guys.
    2StrokeRacer.
  2. 2strokeracer
    Anybody please?
  3. White aerox
    White aerox New Member
    dude your setup is almost the same as mine i am currently using the 90 jet tht my dell carb came with and am using 4.7g rollers
  4. 2strokeracer
    Are you using the stock throttle cable?
  5. wobbly_trials
    stock throttle cable should be fine, you may have to adjust it a bit but on the minarelli engine its just one cable so no oil pump advance to worry about.
  6. 2strokeracer
    Thank you.
