NEW TO THE GAME- CLUELESS ON TUNING NRG
Discussion in 'Scooter Tuning' started by jake mills, May 14, 2013.
  1. jake mills
    jake mills New Member
    HI, i just turned 16 and just bought a 2008 nrg for £550 on ebay and im pretty sure its still resrticted, i have read through the forum but i still dont have a solid idea... i want to tune the moped so it hits around 60mph...im aware i could possibly do this by upgrading to a 70cc bore kit and a sports pipe. can i do anything else? when change the pipe and bore kit do i need to change the 'rollers' or 'upjet' it or anything like that? whats the best order to tune the ped, pipe first then bore kit....blah blah blah. also if i change the pipe would there still be any restrictions on the bike or in the sports pipe? if i do this tuning will the moped still pass its mot as a 50cc? i will be working on it myself although a family friend is a mechanic but i would like to do this independently and learn my way around the bike so take it easy on me lol . any helpful replys will be much appriciated, thanks :)
  2. MiNoR cOnFuSiOn
    best to go pipe and cylinder together, but you can do it in ether order, using a pipe will rape the lil 50 of all its power all the time, the 70 without the pipe would be more power and the same life in the cylinder as the original, both means you have more power and its all nice and high in the revs... any mods require fueling and transmission setup. plenty about rollers/jetting in the guides section. plenty other parts you can buy but an engine is really only as powerfull as the kit and pipe used aswell as the carb feeding it. everything else is simply there to be strong and survive the power (stronger crank and so on) or make use of the power you have (transmission modifications) porting the kit, flowing the cases, altering ignition components and the like add power, lightening and balancing simply makes things stronger/less likely to shake/wear out/cause unnecisasary reductions in power, you dont gain power.
    in short.. id go for the kit, then a second hand pipe in good condition.. leave the rest for now (just set the transmission and carb up) keep the airbox too, always run better/use way less fuel/last longer
  3. jake mills
    ok great cheers, i'll order then tonight! thats all quite confusing but i'll look up about it all and pick it up! thanks alot:)
