New Stage6 inlet manifold and reeds for speedfight 100
Discussion in 'The Workshop' started by kevos, Feb 27, 2011.
  1. kevos
    kevos New Member
    Hi all look for so advice on fitting a stage6 inlet manifold n reeds to a speedfight 100 , i have tryd fitting this part and cant get the bike to start , there were 2 additional metal full bodied reeds , which i didnt fit as there seemd to be 2 portd 1s in place, does any1 have experince of fitting this part , advice would be great thanks
  2. kevos
    kevos New Member
    Got It started, only start with choke, and revs up ,nearly lifts of sidestand , with the rear wheeel engaging and driving , then when disengage the choke , it wont run, does any1 have advice, could it to be with better flow that the idle jet needs changed ?
  3. nathan93
    Gilera Ice
    has it got a standard carb exhaust etc
  4. kevos
    kevos New Member
    No its a Malossi 120, standard head,hopefully a stage6 manifold and twin reeds, 21mm carb, doppler sports air filter n doppler s3r derestricted exhaust, was running fine , just running in new piston n cylinder then going to work on mainjet, but am stumped , just learning , any thoughts
  5. nathan93
    Gilera Ice
    Might need to reject the carb for the reeds you have put in. Try using the old reeds that it had before?
  6. kevos
    kevos New Member
    thanks but want to stick with the stage6 dual reeds , so do think it'll b the jets
  7. nathan93
    Gilera Ice
    no i meen try to see if the old reeds will work
  8. speedfight100unique
    speedfight100unique New Member
    Were did you buy a stage 6 intake for the 100cc i thought they only did one for 50
  9. Bakalakadaka
    Bakalakadaka New Member
    Jiajue Outlaw 150 SS
    I bought a stage 6 big valve intake and motoforce 21mm carb as a bundle from Maxiscoot.com. I put in the 120 malossi kit a few days ago and is being a real pain to get it setup right and now im trying to play around with the reeds to see if it will run better.
  10. Bakalakadaka
    Heres a pic of it
    Stevep likes this.
  11. scubabiker
    how does it run? i like carbon/fibre reeds as if they die, it doesnt take your top end out
    Stevep likes this.
  12. markymark2
    markymark2 Member
    have you got the vacuum pipe connected right ? I used to have a speedy 100/120 and fitted same kit no probs , the metal plates are not reeds.
