Hello! I work in a weilders and I for that I want a wheelie bar so I'm going to make one ! I was just thinking of what to do tho, take my indicatora out and have the bar coming out them or just bolt it to the frame and run no rear pannels! Then when I'm not going to be wheeling then ill run rear pannels! And unbolt it! What do you guys think of this tell me what you would do in my situation!
find wear the frame is behind the rear pannels then maybe cut a hole so the 2 bars come out then it would be stong enuff, i havent seen a new sr with a wheelie bar but i have seen a runner and a ludix.
yehh could do, im going to make it when i work on tuesday well plan it and cut bits and messure it up then if i have tmee ill weild it all up! should be good, ill bolt it to the frame and run no rear pannels if i have too, soo
2x I know of a place in dagenham that does it and meant to have dealt with scoots before if you need a lump done As for wheelie bar, Look at the pics of bare frame and work it out from there mate
sick, where is this place because i cracked my engine the other day, got a new one but would be good to get the old one welded as its been polished up quite well and i realllly cant be bothered to polish the new one.. oh and how much do you reckon they would charge for a crack about an inch and a half long? holla at me :mrgreen:
I think the road is called ridge way Its right next to bikerarealm! Its called brooklands weilding! Shouldn't be much! Where abouts on the engine is it on the top ! Back?
id run no indi's and have the bar cumin out the 2 holes but make it bolt together at the end that will be stocking ouit to so you bolt it to bike then put pans on then bolt bar together
that would never pass MOT the police would be on to you and how you going to indicate at night??? :huh:
