New piston needed ????
Discussion in 'The Workshop' started by sr 125 01, Apr 13, 2014.
  1. sr 125 01
    sr 125 01 Member
  2. sr 125 01
    sr 125 01 Member
    Wat would case the dents ??
  3. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    your posts are actually funnily stupid, how the hell could the spark plug be hitting the edge of the piston?
    lee mason likes this.
  4. Gemma
    Gemma Captain Spooky
    VT 500 E
    Could well be that it was the spark plug at fault. If the electrode fell off and it CAN happen, the plug could have been changed and the loose bit left in their could have caused the dent then it went out of the exhaust....
    The piston is shagged, check barrel and head for scoring or impact dents and replace piston with new rings. You don't want the thing cracking or something stupid later on. So while you have it all apart do the right thing.
  5. MARSH
    It may have been caused by a to tight a squish, hitting the head? the base gasket was a touch on the thin side? I would clean it up, new rings and put it back in !. If you do change it, I'll take that one off your hands !!
