New exhaust..new top speed!....no bottom end...at all!!!!
Discussion in 'Scooter Tuning' started by GRUSSY, May 14, 2009.
  1. GRUSSY
    GRUSSY New Member
    Ok fitted my gianelli reverse exhaust and 62 main jet tonight. good news it now pulls 55mph! on the flat but has no bottom end at all, as in it wont pull away unless i give it full throttle and wait. I'm thinking that my idle mixture/pilot has to be reset to composite for the new exhaust.?? i've got 5.5g rollers fitted and standard clutch springs. which way do i turn the pilot screw and how many turns etc...
    thanks in adavnace...sorry if this is a repost but i cant find no proper info. :tup:
  2. MiNoR cOnFuSiOn
    :confused: how many people are gonna ask the same question about the same thing... regardless of what pipe youve fitted look about, this has been answerd/explained MANY MANY times, theres guides galore on setup... allsorts of people with problems similar to yours with lots of reply's/remedy's... so look befor you ask.
  3. GRUSSY
    GRUSSY New Member
    Ok i'm sorry if i come across a little hasty but i'm really stuck now, i need the bike useable for work. I've tried to research the idle mixture screw but no joy. I'm thinking i need some strong clutch springs lower my main jet to a 60 and fit the 5g rollers. i'm just stuck on the mixture screw.... :unsure:
  4. MiNoR cOnFuSiOn
    it needs clutch springs lighter rollers and the idle mix set....
  5. GRUSSY
    GRUSSY New Member
    Thanks... if i turn the srew clockwise it will richen the mixture, anticlockwise it will lean it off. Do you think i need to slighlt richen the idle mixture? i'm going out in the garage now to fit my lighter rollers and play with the mixture, also shall i fit the 60 insteaed of the 62?
  6. Saint Jonny
    Saint Jonny New Member
    Just change the springs, first and foremost as thats whats causing the wait you're describing THEN adjust the carb. I know there was a guide on this and like it says most problems can be traced back to the transmission, you're idle mixture ain't gonna be the problem more than likely i spent ages trying to get that right and nothing worked, decided to wang in the springs (this was my first ped and first modification btw) and it was fine, fine tuned the screw and bobs your uncle !
    Mainjet, geez check your plug whats it saying ? We could sit here all day discussing it but only you can see that plug !
  7. GRUSSY
    GRUSSY New Member
    Just ordered a evo 2g clutch so i'll fit that and see how i go, gunna check the plug after i've run it a few days, possibly might have to drop down to 60. I'm getting there slowly! lol
  8. GRUSSY
    GRUSSY New Member
    Right fitted the adjustable clutch tonight and its still rubbish! wont set off etc. I've turned the little 7mm nuts clock wise and anti clockwise and it doesnt seem to be making a difference, Am i doing something wrong? i could do with a hand please..
  9. GRUSSY
    GRUSSY New Member
    I've also messed the air mixture screw up. Tuned it all the way in. roughly how many turns out? doing my head in now this scooter, might just flog it and stick with the car
  10. MiNoR cOnFuSiOn
    turn the air mix one and a half turns out, ajust from there, this WONT cure bad transmission or JETTING. you need to change the rollers, they sound too heavy.
  11. GRUSSY
    GRUSSY New Member
    ok i've got the mixture sorted, i've currently got 5g rollers. shall i get some 4g and under ones? say a couple of sets
  12. GRUSSY
    GRUSSY New Member
    The clip on my needle is in the middle and it will only rev up when i open the throttle full if i wind the pilot screw out half a turn. To me its running too rich because if i lean the mixture with the pilot screw it wont rev at all just bogs down. Whats the std setting for the circlip on the needle
  13. Rick-UK
    Rick-UK New Member
    Runner 200
    4.5g area I think
  14. MiNoR cOnFuSiOn
    needle position? roller weight? jet size? i dont even know what bike it is ffs.
    change your rollers, stop fucking about with jets for now
  15. CheekyThomas
    CheekyThomas New Member
    Minor... find the nearest brickwall and go talk to that... itll do as much good :tup:
  16. GRUSSY
    GRUSSY New Member
    Its a zip ac 50cc 2001. put 4.5g rollers in checked plug and its running spot on at 62 just abit unsure about the postion of the clip on the needle. currently in the middle but was on the top postion.
  17. GRUSSY
    GRUSSY New Member
    any body have any ideas?
  18. SimonT
    SimonT New Member
    just put it on the top clip.....
    whats it doing now?
  19. GRUSSY
    GRUSSY New Member
    Before i moved the clip ( was on the top ) i reset the pilot mixture screw. all the way in then 1.5 turns out. it wouldnt rev up without bogging out. so i turned the screw 0.5 turns out from been fully in to get it running something like and reving clean from idle, so i assumed the mixture wanted richening hence thats why i put the clip on the middle slot on the needle....
  20. SimonT
    SimonT New Member
    remember... that screw is the idle mixture.... will only be in effect until the main jet and needle start operating....
    your jet size will determine the mixture while you are riding the bike....
    did you try lighter rollers like has been suggested?
