New exhaust, 30mph, then nothing......
Discussion in 'The Workshop' started by JamesNRG, Feb 17, 2010.
  1. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Hi there,
    Now i got the Doppler S3R fitted, my bike has REALLY slow acceleration, like im just sitting on the bitting point on a car/bike, after a while, it hits the powerband, and flys to 30mph, then goes from a NEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE sound revvin at 8000+ rpm to NUUUUUUUUURRRRRRRRRRRRRRRRRRRR and revs under 6000rpm not going any higher than 30, until i stop, move off again and repeats.
    I got a 60 Main Jet and 4.7gr Rollers, Just ordered a Stage6 box of 2.5gr, 3.0gr,3.5gr and 4gr in a set.
    ANy ideas? I can make a video 2moro if it helps?
    EDIT: ...and yes, The cone has been cut out the manifold.
  2. Aerox-lad
    Aerox-lad New Member
    the doppler s3r has a restrictor in the end pipe aswell. what is your standard mj size? sounds again like rollers are too heavy.
  3. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Standard MJ is 56, I've read, 60-65 is ideal, but i cant get another one in as carb has been cross threaded from a fucking idiot previous owner. THats why i ordered the roller set, 2.5gr should be light enough :good:
  4. Aerox-lad
    yeah if anything wayy too light. but 60 seems ok sort of main jet. try the heaviest set first and then you can allways move down on weights untill you find the right one. and also take the restrictor out of the end can if you havent done so allready :thumbsup:
  5. Blue dwarf
    Blue dwarf New Member
    This has all been answered in another post, he has left the restrictor in the end can and is now wondering why the scoot dosnt perform!
  6. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Yeah going to remove it in a sec, when the pipes cooled down. I'll let you know how it goes, if its the same, ill make a video, even know my road is short, you can't really see as i cant hit 30 on my road, but then again, ill try. :good:
  7. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Okay, Removed the end can restrictor -
    Feels a bit better, acceleration is better, not much but is better, powerband is quicker but still not perfect, still goes to 30mph and dies down, but i managed to get 40 a minute ago on a long road, so i think its roller related, need to be lighter, so when the roller set comes, ill play about and see how it goes :yahoo:
  8. zip50sp
    zip50sp New Member
    lolz dont forget the air/fuel mix i think its wrong judging by the change in engine note after 8000 rpm.
  9. bertie
    bertie Active Member
    '93 Skipper LX125
    There also may be a restrictor in the downpipe not just in the end can.
  10. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    The mixture has been correctly adjusted, It's better than it was, before, it would stall on cold now just keeps running fine, before the bike wouldnt even move after i gave it some, Now it works, just slow accel' and stays at 30mph, im thinking its rollers, so i ordered a Stage6 box of 2.5gr-4.0gr rollers, so i can fiddle with them, got 4.7's in there at the mo' and the mechanic said 4.3's is the optimum but we'll see.
    Yeah, They are both removed :good:
  11. PrettyDodgyDave
    PrettyDodgyDave Member
    Runner 180
    forgive me if you have already stated but have you removed the restrictor between there variator and the front pulley?
  12. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Yes i have, did 40mph on flat, and 50 downhill, now its 30, dunno if it getting into higher gear too early, so rollers.
  13. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    All fixed, put 4gr rollers in, and all working fine, Just slow accel' from pull away, for like 5 seconds, then hits powerband and all fine, is this clutch? If so what springs should i get taa :yahoo:
  14. MiNoR cOnFuSiOn
    get a set of 3 and read the instructions.. they usually have a rough rpm guide wiht the springs to select the ones you want to use..
    but yes the slow off the line is all clutch
  15. JamesNRG
    JamesNRG New Member
    Piaggio NRG Extreme
    Ahh, Okay Minor, Thanks - I'll get a set of 3 standard clutch springs, and sort them when i got some more cashola :wave:
