new carb, now bike wont start
Discussion in 'The Workshop' started by brownej3, Mar 12, 2010.
  1. brownej3
    brownej3 New Member
    YQ Aerox R
    Ok so my problem is that i tried to fit a 17.5mm carb on my aerox today. got everything connected fine but it wouldnt start?
    my setup:
    DR Racing 70cc
    LeoVince Zx pipe
    Polini carbon reed valve block
    4.5g rollers
    harder clutch springs
    Malossi Red sponge airfilter
    I tried needle adjustments aswell as toying with the idle screws but still nothing
    Any help would be appreciated :hello:
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    These carbs come from the factory normally un-tuned, so its un-likely that its setup correctly for your engine from the factory as these carbs are used on MANY other engines/brand scooters.
    I cant really help you much on this one, but you need to do alot of research to find a good base setting to start with.
  3. MiNoR cOnFuSiOn
    id sudgest you dont go messing wiht fueling untill you understand it a little better...
    put your stock carb back on, get reading, attempt this when you have LOTS of jets/needles/rollers/time to fuck about wiht it
