NEO'S acceleration problem.
Discussion in 'The Workshop' started by jakeh, May 26, 2011.
  1. jakeh
    jakeh Member
    i recently de-restricted my yamaha neos, but it goes to about 45mph BUT at about 30mph its really struggles... it takes about 10 seconds to get from 28-32 but from there it is batter acceleration... up to 45..
    i dont know alot about roller weights but someone told me that could be the problem, any ideas?
  2. J4CK
    J4CK Member
    Piaggio NRG 172
    How long does it take to get from 32 to 45?
  3. jakeh
    jakeh Member
    not really tested it.. but much quicker,
    sometimes if i'm on a slight hill, it wont even make it past 30 and i'll be stuck at 30 until i get some flat ground again.
  4. J4CK
    J4CK Member
    Piaggio NRG 172
    Could be variator or you could try upjetting it a little mate mine used to struggle abit but i upjetted it with a open air filter seemed to be better at accelerating and climbing hills.
  5. jakeh
    jakeh Member
    okay cool, i'll look into getting a new main jet, also how much carb adjustment is needed to change from the stock airbox to an open air filter.. i put my air filter on instead of the airbox, but it kept stalling/loosing power, i have no idea what to do cos i'm a noob.
  6. J4CK
    J4CK Member
    Piaggio NRG 172
    Look what size jet is init and then buy a jet pack so say if its main jet size 50 buy a jet pack from size 50-75 or 80 ish you wont and work your way up in 2's until it runs just right. when i put a open air filter on my nrg 50 it had a 65 main jet in and when i went past 30 mph it bogged down so i tryed 70,75,80,85,90,95 and it still did it and i ended up having a 102 jet in but after that it worked fine :)
  7. jakeh
    jakeh Member
    Just tried it now with a full tank, took almost half a mile to get past 30. Not cool :/
    definitely looking into this,
    also, anyone know the stock jet size for a yamaha NEOS, i had a look ion the manual but couldn't find anything...
  8. mad racer
    mad racer New Member
    yamaha jog-r
    have u tryed new rollers as ur old ones might be sqaured off
  9. jakeh
    jakeh Member
    Not yet, i'm probably going to get new rollers when i find out the best weight for my setup
  10. jakeh
    jakeh Member
    new rollers did the trick... i went from 6.5g to 5.5g. still going to upjet in a couple of weeks
