neos 50 with no spark?
Discussion in 'The Workshop' started by eddo241, Oct 13, 2010.
  1. eddo241
    eddo241 Member
    NEOS
    once again the neos has caused a 7 mile walk thers no spark at the plug ive tried changing the plug,still nothing the batts fine and the main fuse any ideas? :confused:ick:
  2. nathan93
    Gilera Ice
    check the coil pack and ht lead also makesure the wires to the coil are not loose
  3. eddo241
    eddo241 Member
    NEOS
    is the coil pack wot the ht lead is attached to? also the plug seems dry but theres fuel n oil running thru the pipes, it cut out a few times n restarted no prob then got a noise n that was it.
  4. eddo241
    eddo241 Member
    NEOS
    now will spark once in a while but also shocks u thru the brake lever
  5. sammyboi
    sammyboi New Member
    gilera runner
    threw the brake lever lmao? what! never heard of that happening. and yeah the coil pack is what your ht lead is pluged into
  6. lipsmoker
    lipsmoker Member
    Faulty connection, wired up wrong at the coil sounds like it,
    See if it shocks you anywhere, Like the engine frame its likely the whole bike is becoming live due to someone sticking a live wire onto an earth point, or its touching earth and touching live at the same time, Aka sometimes sends power to the plug or sometimes sends it to the frame
  7. eddo241
    eddo241 Member
    NEOS
    thers only 2 wires on it 1 plugs direct to the coil the other bolts to the frame as an earth
    kepps making the batt flat
  8. eddo241
    eddo241 Member
    NEOS
    now have spark but it still will not start, even with new piston?
