Needles and pilot jets
Discussion in 'General Tuning' started by ramo, May 8, 2012.
  1. ramo
    ramo GoldMember
    When do these need to be changed? I see lammy and old Vespa owners change them as as often as main jets are done but rarely ped tuners bother? Is it unnecessary or overlooked?
  2. steve
    steve I dont skinny dip, I chunky dunk
    Piaggio Zip sp 172cc
    Iv never changed one tbh, i change my needle for throttle responce really thats about it haha :)
  3. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Needles aren't so much of a problem as they work off the main jet.
    The pilot jet is only changed for idle and when you let off. Usually changed when the mixture screw adjustment isnt enough, for example my Mixture screw was richened as much as possible, and it was just about okay, so by going up 2 sizes on the pilot jet I could wind the screw back out to about the middle and retain some room for adjustment.
    steve likes this.
  4. steve
    The thing is i know what the mixture screw does and everything but i just dont know how to tell when you have it right for your bike???
  5. FiddyRox
    Warm the bike up, and turn the screw out almost all the way. Then start to screw it in 1/2 a turn at a time, until the revs drop.
  6. steve
    Drop how far ?? Untill like a decent tick over sort of pace...
  7. FiddyRox
    Yeah, and then usually another 1/4 turn after that. Usually when you have an unsteady idle that's kinda high, it means the mixture is lean. So either there is an air leak or you just need to turn the mixture screw in a little bit.
  8. steve
    okokok that makes more sence now haha thanks :)
  9. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    steve likes this.
  10. steve
    That was really helpful..
