need urgent help with rear wheel :)
Discussion in 'The Workshop' started by mods, Feb 2, 2009.
  1. mods
    mods New Member
    is there some trick to getting it off?
    it wont budge and i got two people holding it
    i need to know soon how to get it off :)
  2. wobbly_trials
    assuming you've removed the nut it should just slide off the shaft.
    removing the nut you want either an impact gun, or a long breaker bar and someone to hold the back break.
  3. mods
    mods New Member
    kk heres the thing
    i got the engine with no brake attached
    so basically i have an engine block with a back wheel attached
    and i need to get that nut off..
    i just got a socket wrench lol :/ n i need to do it asap.
  4. Vesta
    Vesta New Member
    Tired hitting the wrench with a hammer while someone wedges it between there feet?
  5. nrgandy
    nrgandy New Member
    i used to jam a axe handle in lol but now use impact gun
  6. mods
    mods New Member
    We put a hammer handle into a place (padded it so it wont scratch;))
    and i put all my weight on it...
    i dont want to break it because its not my wrench so i dont want
    to hammer it.
  7. wobbly_trials
    block of wood between the wheel spokes wedging against the casing, then turn the engine upside down, preferably on grass, use a long breaker bar and jump on it. mind your shins though.
  8. mods
    mods New Member
    I dont have a breaker bar.
  9. wobbly_trials
    a peice of scaffold tube over the end of your ratchet then
    oh and drop the size of your avatar a bit ;)
  10. nibbles
    nibbles Active Member
    init lol mods is tekkin up half ya band width .its a bugger to get off innit m8 iv got all mine off with that rench but i dont thinnk that ones ever bin removed thus is stiff .if u can get it to a garage ill get ma m8 to get it off with air ratchett maybe?
  11. mods
    mods New Member
    but we need to do it before like wednesday/thursday
    so i can clean it so i can bring it to yours for some flowing
  12. WOLFFY
    WOLFFY New Member
    LOL you tart, just use your muscles.
  13. shinigamii
    shinigamii New Member
    tits and tits.
    Right wedge the back wheel using blocks of wood. Get your ratchet cover in a dish towel and give it a good old whack with a hammer this should loosen the wheel nut withought breaking your mates ratchet or harming your scooter. The next few turns will most likely be tight but not soo tight you cant get it off.
  14. mods
    mods New Member
    mate i had a 15stone guy put almost all his weight down on in and it
    didnt budge.
    (lol nibbles darren tried)
  15. px166bajaj
    px166bajaj Active Member
    Take it to Kwik Fit, give him a couple of Kwid and get him to take it of with his air ratchet.
  16. Jamie
    x2
    i took the handle of my push scooter to do my old runner 70 LOL worked with hardly any force
  17. wobbly_trials
    to be fair, i did have one that i litteraly had to wedge under the car then use a 4 foot long scaffold bar to undo it.
  18. one7twoboi
    one7twoboi New Member
    LOL
    like baj said, if ya can, take it to a local car garage and ask if he'll undo it with the air gun
  19. wobbly_trials
    I have an airgun, not a cheapo one either, and that wouldn't shift it, so i went up to the 3/4 inch drive one and that wouldn't budge it.
    Thats a CP (chicago pneumatics) windy gun running at 160psi.
  20. px166bajaj
    It was set on "undo" right? :w00t:
