need some crank help
Discussion in 'General Tuning' started by webber, Dec 6, 2008.
Thread Status:
Not open for further replies.
  1. webber
    webber New Member
    whats the easiest way to centre the crank and set endfloat???
    Know of any guides?
    thanks
    webber
  2. wobbly_trials
    End float can't really be set, there should be next-to-none on a fresh build, the best way to center it is with patience, a rubber hammer and a set of feeler (thickness) gauges.
  3. MiNoR cOnFuSiOn
    best way to gain correct endfloat is to build the engine correctly.. this thread title should be "i want to try rebuilding my enigne" all the info you need is in ANY 2t build manual.. or the piaggio manual altho they build it different to the way i do...
    basicly endfloat is the result of doing it right, doing it wrong means you CANT correct the lack of endfloat. read up.. anything peopolke will explain on here has already been said, in detail.. get donw ya library
  4. tErr0
    Plus your topic title is a pile of wank.
Thread Status:
