Hi i recently bought a 125 typhoon only to relise i bought a right lemon so had to strip the bike down completly nearly put everything back together again but have no clue were all the plumings go e.g oil line petrol lines so on i did take pictures but daughter decided to delete them as she wanted room for pictures of herself lool anyone wiv any pics would help cheers
Hey bud get urself the Haynes twist and go manual you should invest on one anyway it'll become ur bible
cheers mate did look for one in halfords but they seem to have gone anti bikes in the one i use ill order one online
the oil system starts as a black pipe coming from the oil bottle and goes into the engine casing through a square rubber grommet and there should be a smaller pipe coming out of that square grommet, that goes onto the side of the carburettor. The fuel system has two pipes one is for petrol and connects to the carburettor and the other is a vacuum pipe that goes onto a pipe fitting next to the inlet manifold (reed block) if you can see the vacuum tap under the fuel tank it has the two pipes on it the top pipe is fuel and the bottom is vacuum
http://www.aonsc.co.uk/pdf/vespa-workshop-notes.pdf http://scootercommunity.com.au/files/folders/piaggio/entry928.aspx There you go. It may help, it may not, I haven't read it.
