yamaha aerox 70, italkit 70cc kit, 24mm oko carb, yasuni r exhaust, stage 6 reed block, stage 6 rt clutch, stage 6 sp variator with 5g rollers, primary and secondary gear up. problem recently happened dont know the cause, when i pull off it seems alright, i then get to a decent speed (above 30) then if i release throttle then engage throttle, it isnt revving and sounds like a four stroke, it is like it has flat rollers but they are brand new, any help would be appreciate, feel free to ask any questions about the problem, i have tried to explain the situation as best as i can thanks, sam.
A 24mm carb seems a bit too big for your setup, the airflow through the venturi at lower revs is possibly too slow to properly atomise the fuel which could cause the issue.
hi, my aerox has had this set up for 2 years, it has been fine for this long, only minor problems going wrong ect, i dont understand why it has happened recently, ive cleaned carb and reeds, tried rejetting it, but had no progress
Dont mean to upset you but mines was doing this. Cost me £330 in total to get it fixed and it was worked again for a few weeks until it started again. After a month had or so had gone by It was getting worse with the throttle like it was struggling with the gearing and started to lose power up hills until eventually it wouldn't go above walking pace.... I got home that day after pushing it home and pulled the full engine out I had all new Rollers Belt Watet pump repair kit Carb Inlet manifold Oil seal choke Reed valve Re jet Air box Clutch springs
what do you mean by worn loose? it was done up by an impact gun and still very tight so wont of come loose
I suppose a faulty gear up kit could be the cause but it does sound an awful lot like my problem and that was definately air flow
Took it to psn scooters they had it for 4 days turned out it was a oil seal still cost me 200 it happened again last week so I took the engine out and im waiting fot my piaggio 125 so I can weld it up and make it a 172 aerox
No they change all sorts trying to find out what it was so I ended. Up paying for all the parts I.e carb inlet manifold reed valve load of new seals
i know its not what wewere talking about but how would i guess what sort of price my aerox is worth? what would u need to know?
04 plate, 5000km, italkit 70cc kit, 24mm oko carb, yasuni r exhaust, stage 6 reed block, stage 6 rt clutch, stage 6 sp variator with 5g rollers, primary and secondary gear up., decent condition, its the monster energy ped in my profile picture, full matte black spray job, monster stickers, and laquered, all together spray jobs and stickers cost £900
The milege is good and if I looks in good condition that will help boost the price. The age does let it down but if it runs well that brings the price back up at a guess i'd say about 700-800
