Need Help Jog RR
Discussion in 'The Workshop' started by Ross1308, Nov 20, 2008.
  1. Ross1308
    Ross1308 Member
    Hi guys, earlier today fittd my mates Jog RR with a TT Pipe and 5.0g Rollers, i didnt touch the carb, hes now at my house because on the way home he went to go off a roundabout onto the dual cariageways and pulled the throttles and it just bogged and died, i went and pushed him to my house, the bike is trying to start (so its not seized) as its turning over beautifully, i took the airbox off and floatbowl changed it from a 62 jet standard to 70, still didnt fire, then upon slightly moving one of the pipes which hang by the carb (the thickest one) it came of, im pretty sure it ataches to the fuel tank, not to sure really, need help asap he needs to get home tonight.
    Thanks
    Ross.
  2. Vesta
    Vesta New Member
    Sounds like a heat seize why didn't you upjet?
    If its heat seized it will try and start and probably will do eventually, i've rid about 50 miles on a heat seized barrel i though tit was a carb problem :L :emb:
    So the fuel pipes come? Whats the big deal about that either you've explained it a bit fuddled up or its nothing major
  3. Ross1308
    Ross1308 Member
    I think its resolved, no its not heat seized, loads of compression, there is spark and its turning over nicely, jus had it confirmed by dec that the pipe which has come off is the Vacum for fuel, will get it back on tomorrow and let you know, just your opinion guys, its the pipe which hangs by the airbox and is connected to fuel tank.
  4. Vesta
    Vesta New Member
    Well there'll be 2 coming out the tank yeah?
    Suck on the one thats out, if it tastes of petrol, if not its the vacuum lol.
    Glad its sorted
  5. Ross1308
    Ross1308 Member
    aint sorted yet mate, gotta strip plastics to get to tank tomorrow, its a brand new Jog RR its minttttttt rossi rep, was sold to him by a local dealer by me and they had to build it all there selves, like put carb together and shit and they left a sleeving in one of the pipes, so it was blocking fuel and now they fixed that, hes having more trouble, hopefully this is the last, it smells of fuel but dosnt go to carb, like i said it hangs next to airbox by float bowl overflow.
  6. Crana
    Crana Active Member
    TAKE IT BACK
  7. Ross1308
    Ross1308 Member
    put a pipe on it for him today and rollers, cant take it back now lol, was running fine, he must of hit a bump quite hard and knocked the pipe out obviously my dealer didnt connect it properly, Stupid nobs they know f all about peds.
  8. Ross1308
    Ross1308 Member
    So the pipe which came of was from the cat converter, fixed it now anyway his spark plug was fucked, and very black and oily, the mixture screw is just bottom/left of the idle screw am i right, which way should i turn it to correct this, thanks
    Ross
  9. Vesta
    Vesta New Member
    If its brand new why cant you take it back to the dealer?
  10. NJH
    NJH New Member
    no, the idle speed is to the bottom left of the one where the airbox goes, where the airbox goes is the idle mix,
    if the pipes for the cat on tha standard pipe i dno wher ur gna put that as it wont have a cat on the tt, cant you make the bike standard again take it back, get them to fix it then do it again, jus fit the pipe and rollers, dont touch tha carb
  11. MiNoR cOnFuSiOn
    if you change the pipe you can just forget about the cat.. hardly a cat anyway, its air recirculation (adds fresh air to the exhaust gasses to lower emmisions altho the emmisions are the same,t heres just more fresh air comming out wiht them.. fucking backwards and pointless if you ask me)
    as for "the plugs black, how do i fix this" dont fuck wiht things you dont understand.. put it back to stock.. get the carb setup right, then fit the pipe and get the rollers right.. upjet set the needle THEN sort the idle mix.
    why are you doing work to other peoples NEWQ bikes if you dont understand simple carb setup? yes by all means experimentation is the best way to learn, but not wiht somone elses gear m8
  12. Vesta
    Vesta New Member
    x2
    CZYNRG's ped ended up in my garage for a night cos i made a big error because it wasn't my ped so perhaps i didn't take much attention.
  13. Ross1308
    Ross1308 Member
    i didnt just experiment on it, he asked me to fit his pipe and rollers so i did, i didnt expect the plug to die and pipes to start falling out, so i couldnt just leave it how it was, he was gonna take it to the place i took it to, to get it upjetted, and he needed to get home, so i couldnt just say i dont know your fucked lol, Tbh i learnt alot from trying to fix it, Anyway i fixed it now, and hes gonna take it to be jetted and carb setup properly tomorrow/
  14. Vesta
    Vesta New Member
    Taking it to Getspeed ? :w00t:
  15. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    umust have money to burn up there, both got brand new bikes, both fuck them up, then both pay shop to get carbs set up for chainging the pipe! :msn1: not havin a pop just wish i had money to thro away
  16. Ross1308
    Ross1308 Member
    Not really, its just we both have jobs and dads who trust enough to put the bikes on there credit cards, i didnt fuck mine up, getspeed fucked mine up, i didnt fuck his up, not being jetted fucked his up and all i did to it like i said was put a pipe on it, im no expert thats why i dont wanna fuck with it, then he cant blame me. Its cool mate dw
  17. Vesta
    Vesta New Member
    What you mean not being jetted fucked his up mate?
    No offence but if ya gonna fit a exhaust you gotta do a full job and setup his ped properly pal
  18. Ross1308
    Ross1308 Member
    All he asked me to do was fit pipe and rollers, i told him to take it very easy, and take it the shop ASAP, Fuck sake
  19. Vesta
    Vesta New Member
    Taking it easy wont mean shit man youi know how to upjet a carb you should've done it, i've learnt the hard way seized a 70kit by not upjetting when i changed to a proper exhaust
    Anyway mate live and learn we both learning eh
    :beer: :beer:
  20. Ross1308
    Ross1308 Member
    hes got a 62 at the min, gotta order him a jet, wa size u rekon ?
