need help fast
Discussion in 'The Workshop' started by Dwaine, Dec 31, 2013.
  1. Dwaine
    Dwaine Member
    piaggio zip
    i was out on my zip 50cc today when it started peeing it down with rain and my bike kept bogging out,,,,i manage to get home and then turned of and left it.....now it will not start ive checked it has a spark and dose but the plug is megga black....it has a dellorto 17.5 carb with a 98 jet and sponge filter.....really need to sort it for work please any ideas,,,,THANKS
  2. leroya500
    leroya500 Active Member
    Clean your plug and lean the mixture a little, try and ride
  3. Dwaine
    Dwaine Member
    piaggio zip
    how do i lean the mixture ive cleaned plug and it deffo sparks on side of frame
  4. leroya500
    There will be a screw some where on the side of carb turn it 1/4 of a turn
  5. Dwaine
    Dwaine Member
    piaggio zip
    left or right ill try that
  6. leroya500
    One way you'll hear the engine speed up the other it'll slow down, u want it too slow down
  7. Dwaine
    Dwaine Member
    piaggio zip
    but it wont start for me to that
  8. leroya500
    Turn it just a little then, remember which way then try to start it and adjust as required
    Just to check, you have got fuel?, does the plug get wet after you've cranked the engine?
  9. Dwaine
    Dwaine Member
    piaggio zip
    is this the timing screw you mean or i think there is another one next to like a flat head screw
  10. Dwaine
    Dwaine Member
    piaggio zip
    yes mate plug is abit wet but im also loosing light to work know lol
  11. leroya500
    The other one!
  12. leroya500
    Another one to check, how much charge has your battery got?
  13. Dwaine
    Dwaine Member
    piaggio zip
    would battery charge matter from kick start tho leccy dont work
  14. leroya500
    Does if it's really dead on cvt ped
  15. Dwaine
    Dwaine Member
    piaggio zip
    whats cvt mean......
    ive had nothing but issues with the bloody thing since i brought it GGGRRRRR
  16. leroya500
    It's the type of gearbox ie rev and go!
  17. leroya500
    Try this dude, take the air filter off and try to start it
  18. Dwaine
    Dwaine Member
    piaggio zip
    i did that still nothing lol
  19. leroya500
    Spark plug gapped correctly?
  20. Dwaine
    Dwaine Member
    piaggio zip
    yes mate its only about 3 weeks old and tried 2 pluggs ,,,like i say was running ok till in the rain started bogging managed to get home know not start
