nearly completed one problem
Discussion in 'General Scooter Discussion' started by typh70, Jan 19, 2009.
  1. typh70
    typh70 New Member
    hiya
    over the last month ive been conerting my zip 50 to a 125.
    ive had loads of problems as this is my first time doing a conversion.
    ive got everything done now im just having trouble gettin the thing going.
    im running an open air filter as the airbox now doesnt fit.
    the only way i can get the bike started is to squirt a bit of petrol down the manifold. the bike will tick over for about half a minite before dying out.
    ive cleaned the carb loads of times and done the vacum and it still doesnt want to stay alive. the only way i can keep it going is when the bike is dying is to smother the air filter to stop any air gettin in then, unsmothering the filter and it will tick over for a bit longer :confused:arc: any ideas
    i know this is a noob question butt i really want to get it on road and mot's n all that soon :)
    thanks tom (sorry for the essay)
    ive also changed the fuel tap
    one thing ive noticed is that theres a nipple on the carb with no hose going to it. right at the front next to near the manifold. its a mikuni carb btw
  2. moansss
    moansss Member
    there should be a pipe coming from the petrol tank going to the nipple that you have left out. (right near the manifold).
  3. typh70
    typh70 New Member
    ye theres a vaccum pipe that i have connected to the big gold nipple coming out the actuall engine next to the manifold but theres a hole nipple left out on the carb. :confused:
    when i got the engine the nipple next to the manifold that i now have the vaccum pipe on was blocked up.
    shall i block it up again and use the nipple on the carb for the vaccum pipe
  4. moansss
    moansss Member
    yh block the nipple on the actual engine, and put the other pipe from the petrol tank on the carb.
    make sure its blocked good though otherwise will be hard to start.
  5. typh70
    typh70 New Member
    okay mate :) cheers gona walk it to the garage now get some petrol. see what its saying let you know how it goes
  6. alexsr70
    alexsr70 New Member
    it should be fine once you done that
    it sucking too much air, so thats why it runs a bit better when you cover the filter
    im assuming its running fine now, seeing as you ent replied all day lol
  7. Biggie
    Biggie New Member
    Narrrr hes probably lost :rofl:
  8. typh70
    typh70 New Member
    LOOL i nearly died had it idleing a bit on the way home from garage and pulled the throttle back a bit and it got stuck! managed to reach for the key quick tho.
    i closed the hole and it still didnt work so i checked the jet again i had a spare jet and checked them both out and the one i had in there was clogged. put the new one in and its running sweet :D i got a few vids and picks ill put up soon
    throttle sorted btw just needed adjusting
