Hey, I have on my TPH 125: 150cc Skipper engine AC 93 main jet Malossi carbon reed valve Malossi red clutch springs malossi white torque spring malossi 10.5 gr rollers Just bough a new variator and a new crank with bearings and oil seals, because the old once was corrupted casue the crank wasn't straight. I'm thinking about adding two NRG 98' wheels, and maybe a TOP-PERFORMANCE front fork, would that be the right step?, or maybe I should use the money and get a cylinder kit? thanks
you've posted recently that your front forks are no good right? then get them sorted and then go for the wheels so you have better handling to cope if you do decide to buy a bigger bore.
